Henglong SuperSport Remote Issue
Hello all:
I have a HengLong Stuck-Up buggy with HL SuperSport remote. My servo gears became stripped and I ordered a replacement servo. I have installed the server but now have an issue I can't figure out. The controls are reversed - When I use the steering wheel to change direction is operates the power, When I use the pistol grip is turns the wheels? Anyone have any ideas on what I need to do to get the controller working properly? Thanks, Stan<br type="_moz" /> |
RE: Henglong SuperSport Remote Issue
Have you tried reversing the channels that the servos are pluged into?
Bruce |
Agreed sounds like a plugged into the wrong hole booboo.JE
I have tried every combination I can think of - I have it partly working.
Now the Gas works correctly and the steering works but when turning the steering wheel right it goes left and vise versa. Any thoughts on that? Thanks, Stan |
