HK 2.4 rx antenna mount ok?
1 Attachment(s)
This is a Turnigy 9x using HK or Flysky compatible 2.4 RX. Neither of these have been flown yet. Are these 2 locations ok? Apparently the large portion red shrink part is the important part.
One is a close range Pluma that is tucked under a carbon fiber rod. The other is a electro-stik with 2 insulated steel control rods about 1/2 inch away. Thanks for looking |
RE: HK 2.4 rx antenna mount ok?
Thats about the way I mount them. I have used hot glue, tubes, to hold them in place. So far have not had a problem.
Buzz. |
Both have been rock solid. Worked well. Thanks.
