Spectrum DX7 ?
I have a Spectrum DX7 Tx and I am wondering if there is a way to get the Tx settings to default . Any help appreciated .
Jeff |
RE: Spectrum DX7 ?
ORIGINAL: 2PUPS I have a Spectrum DX7 Tx and I am wondering if there is a way to get the Tx settings to default . Any help appreciated . Jeff |
RE: Spectrum DX7 ?
Yes, you can reset each model memory to factory defaults. Called "Data reset" in the radio.
First go to and select the model number you want to reset. Then turn off the TX. Proceed as follows 1. press the "down" and "select" keys simultaneously then turn on the TX. 2. press the "up" or "down" key until you see "model reset" on the screen. 3. use the "select" key to select "data reset". 4. When "data reset" is selected, pressing the "clear" key will reset the data to the factory default settings for that model. Remember, you must first turn on your TX selecting a model just as if you were going to fly that model. Then turn the TX off and start with step number 1. You must do a "data reset" for each model memory. I don't know of any way to reset the whole radio with one procedure. |
RE: Spectrum DX7 ?
Thanks for the info guys , much appreciated .
