Hobbico vs. Tower Hobbies servos
Hello,
Has anyone had any experience with these? I'm looking at the metal geared, HT versions for a GP 70 Revolver. Since I have to purchase 4-5 of these, i wanted to see if these were a viable alternative to the same spec servos from Futaba or Hitec. Thanks in advance Fellas! -Steve |
RE: Hobbico vs. Tower Hobbies servos
Re-badged Futaba and Hitecs mostly.
I have never had any issues with my Tower, or Hobbico Command, servo's. Open them up and you see the Hitec serial ID's on them. |
It seems the smaller ones are typically Hitec, the larger are Hitec and Futaba. There may or may not be a name brand clone, it could be a similar servo geared to Hobbico's spec. Not sure why there is a difference in price between Tower and Hobbico servos, they are usually the same servo and sometimes Tower is more.
I bought a fleet of the CS-10 or something, but still haven't started the project yet. The specs are good. Maybe this weekend. |
I have been flying my Balsa Nova 120 (80 inch wingspan, Mark 1.35 Glow engine) for about 3 years using the Hobbico CS-160 Standard Digital HT/HS 2BB MG and the Tower Hobbies TS-160 Std Digital HT HS 2BB MG Servo. These have been good servos....haven't had any problems with over 250 flights. One of the Hobbico servos arrived dead on arrival. I phoned Tower and they immediately replaced it....didn't even ask me to send back the dead servo. The Balsa Nova 120 will put higher loads on the servos than your Revolver. I recommend them...really good servos at a very reasonable price.
Thanks Guys for the reply.
Sounds like either brand is a very good value. -Steve |
'Oughta be similar since Hobbico owns Tower Hobbies and a BUNCH of other hobby companies.... :)
ORIGINAL: 8thscale Hello, Has anyone had any experience with these? I'm looking at the metal geared, HT versions for a GP 70 Revolver. Since I have to purchase 4-5 of these, i wanted to see if these were a viable alternative to the same spec servos from Futaba or Hitec. Thanks in advance Fellas! -Steve <span style="font-size: smaller">"Hobbico - Tower System 2000 servos are identical to either Futaba or Hitec (except the rebadged Hitec digitals are not programmable), varying only by label and part number. Tower brand are pre-fixed TS. Hobbico are pre-fixed HS. The Hobbico brand is sold to hobby shops, while the Tower brand is sold only by Tower Hobbies. Both brands are marketed by Great Planes. Digital = TS-140 is a Futaba built servo and the TS-160 is a Hitec built servo. Analog = TS 3000 series servos are made by Futaba. HS & TS 2000 series servos are made by Hitec, TS-51= Hitec HS-300. Hobbico CS65=Hitec HS-605, CS67= HS-425, CS71= HS-615MG, CS72= HS-700BB, CS59= HS-77BB, CS35=Hitec HS-225BB. <font color="#ff0000">Wire colours and connectors are good indicators of the respective HS-TS servo manufacturer.</font>]" </span> NB:The rebadged Hitec digital servos are not progammale as are those with the Hitec label. . Hitec Servo Chart (pdf) Dec 2012 Alan T. Alan's Hobby, Model & RC FAQ Web Links |
