RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   9C and Snap Roll programming (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/1131565-9c-snap-roll-programming.html)
jzinckgra 09-12-2003 10:30 AM
I just bought a new 9C and started reading the manual and playing with the Tx. Just a couple general Q's. How do you program the trainer switch to function as a snap roll switch? I mean, I can read the manual on how to do it, but am confused as to how much control surface throw I should program for each surface (aileron, rudder, elevator). Do you start with 100% for each? And what if this doesn't result in the desired effect while at the field? Anotherwords, if you can do a perfect snap roll using just the sticks, how do you go back and program the Tx to do the same thing, not knowing exactly how much (in %) you moved the sticks at the field? Isn't it a lot of trial and error on the programming? Do you just keep adjusting the % control throws until you get a good roll? This question applies to mixing as well, but for now, I'm just curious in the snap roll. Thanks .
Lynx 09-13-2003 01:29 AM
RE: 9C and Snap Roll programming
Considering how many variables there are in flight, is it even possible to do that?
flatfour 09-13-2003 11:06 AM
Just leave the 100% for starters.
Try and set DIR SW1 to switch G. You can then have 3 diffetet direction settings
