PCM 512 to 2.4 convesion
Hi.
I know this is a very common conversation, but I already "dig" in the net but can not find nothing for my radio. I have a FUTABA <span id=".reactRoot[1].:1:0:1:comment3131412581498_1306476.:0.:1.:0.:1.: 0.:0.:0:2" data-ft="{"tn":"K"}"><span id=".reactRoot[1].:1:0:1:comment3131412581498_1306476.:0.:1.:0.:1.: 0.:0.:0:2.:0"><span id=".reactRoot[1].:1:0:1:comment3131412581498_1306476.:0.:1.:0.:1.: 0.:0.:0:2.:0.:0">FP-8SGHP 512 PCM and I would like to know if it´s possible to convert to 2.4 and how?? Many thanks. André </span></span></span><h1 id="itemTitle" itemprop="name" class="it-ttl"></h1> |
RE: PCM 512 to 2.4 convesion
If it has a module and is capable of PPM (FM) then it can be converted.
Mike. |
On the radio manual say PCM(FM) and nothing more.Do I have a solution for this??
<span style="font-size: smaller;">ORIGINAL: lordz1978 Hi. I know this is a very common conversation, but I already "dig" in the net but can not find nothing for my radio. I have a FUTABA <span data-ft="{" id=".reactRoot[1].:1:0:1:comment3131412581498_1306476.:0.:1.:0.:1.: 0.:0.:0:2"><span id=".reactRoot[1].:1:0:1:comment3131412581498_1306476.:0.:1.:0.:1.: 0.:0.:0:2.:0"><span id=".reactRoot[1].:1:0:1:comment3131412581498_1306476.:0.:1.:0.:1.: 0.:0.:0:2.:0.:0">FP-8SGHP 512 PCM and I would like to know if it´s possible to convert to 2.4 and how?? Many thanks. André</span></span></span></span> Futaba - Compatibility - Interchange of Modules between 8U, 9C, 9Z , 12Z& 14MZ However, there are one or two Chinese manufacturers who supply a "package" which may fit inside, beside the newTX-R Transmitter Ready 2.4GHz system. . AnyLink enables your transmitter to send out a true, 2.4GHz signal <span style="font-size: x-small;">"and operate with all of the interference-free dependability of a frequency-hopping, spread-spectrum system. "</span> FP-8SGHP set to PPM will enable this to work through trainer socket and permit use with all the TXR planes including those to be released by other manufactures, including Hitec RCD, with the open source SLT, [FAQ] Further systems available below: "Radio Systems, Accessories, Alterations and FAQ" at Alan's Hobby, Model & RC FAQ Web Links Alan T. |
You can gut a TM-8 module and convert it to FASST if you want. Requires some minor wiring expertise. Works through the trainer output. Probably not legal.
The 8SG transmitter did not have a trainer output, nor were you able to choose PPM transmission. It was PCM512 only. We do not believe you can successfully convert this transmitter to 2.4 GHz operation.
ORIGINAL: Bax The 8SG transmitter did not have a trainer output, nor were you able to choose PPM transmission. It was PCM512 only. We do not believe you can successfully convert this transmitter to 2.4 GHz operation. |
I already tried a feew things like, buy a Corona System 2.4 the module fits in the pins but it doesn´t transmits.
On this lasts days I have been searching but I realize thats going to allmost impossible to convert this radio, only if there are any roket scientist witha great idea..... |
Like what was said in another thread, if you are able to trace the PPM signal and solder a wire on the board to pull the signal. Plug and go will not happen.
I don´t have the "machinery" required to trace the PPM signal.....
What part of Bax's post don't folks understand[:@]
The radio in question does not have a trainer port for the simple reason there is no PPM signal available in the radio to feed to a trainer port;) These radios where PCM only. Pete |
ORIGINAL: pilotpete2 What part of Bax's post don't folks understand[:@] The radio in question does not have a trainer port for the simple reason there is no PPM signal available in the radio to feed to a trainer port;) These radios where PCM only. Pete |
Trace the main board... Always could go Microstar conversion.
What!! Me get upset, nevvvver:)
BTW, your advise in regards to the radio is on the money, time to retire it;) Pete |
An Idea:
Get a spare 512 receiver and take out the decoder board. Run the 512 modulation in the transmitter through the decoder and produce the PWM outputs. Putting the outputs into a PWM frame is now trivial for a EE tinkerer. Hack a TM-8 module and you have FASST. PCM 512 was extremely slow. This is the reason that I skipped it and waited for 1024. But only you know why you want to save this transmitter. A neat MicroStar conversion would make more sense and already mentioned above. |
That may be a good idea, but the problem is , I´m not very good whit electronics....I only want to save the radio beacause its nice and in the old times never fail, and now I have a lot more planes and a extra radio is always good.
Pickup a used 9c and convert it using the corona unit you have.
Originally Posted by Four Stroker
(Post 11538109)
An Idea:
Get a spare 512 receiver and take out the decoder board. Run the 512 modulation in the transmitter through the decoder and produce the PWM outputs. Putting the outputs into a PWM frame is now trivial for a EE tinkerer. Hack a TM-8 module and you have FASST. PCM 512 was extremely slow. This is the reason that I skipped it and waited for 1024. But only you know why you want to save this transmitter. A neat MicroStar conversion would make more sense and already mentioned above. WHAT??? the Coke its invented???? only kidding... ;-P http://www.rcuniverse.com/forum/clas...n-success.html |
I don´t have the "machinery" required to trace the PPM signal..... http://www.digitalso.com/hu9h.jpg
http://www.digitalso.com/hu9h.jpg You can gut a TM-8 module and convert it to FASST if you want. http://www.digitalso.com/hu9h.jpg
