Low Voltage warning
Hi
What is the normal voltage warning setting for low RX battery level for 2cell LiFe battery when using telemetry monitoring? |
G'day Mate,
I set mine at 5volts, with my DX9, & Spektrum telemetry, but It's never got that low, I usually run out of time, or the day gets too hot. Cheers |
there is no safe low voltage monitoring for LiFe batteries due to heir flat discharge curve, i log my voltages in flight and they don't change much at all between fully charged and DEAD, you just have to keep track of them by knowing how many mAh you use per flight and what your batteries are putting out.
