DX6i question
Can the DX6i be programmed to have 2 flight modes including different trims that is selected by flipping a switch? What I want is a "launch mode" that includes some up elevator trim to use when hand launching planes and then flip a switch after the launch to put it in a "normal flight mode".
It doesnt have any mode based programming per se. Pretty basic radio.
To do what you want to do you can make a Mix of Ele>Ele with a little bit of Rate to give your up Ele trim on a switch. |
Thank you, I'll give it a try.
