RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   DX7s Transmitter Timer Operation (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/11635147-dx7s-transmitter-timer-operation.html)
Joystick TX 12-26-2016 05:40 AM
I have a DX7s transmitter and I usually set up my Timer to start counting down at 75% throttle. The throttle set to low when the transmitter is turned on and the timer does not start counting down until the throttle is advanced past the 75% point.
I'm trying to set up a different airplane now and had to set the throttle servo from Normal to Reverse. Now when I turn on the transmitter, the timer starts counting down immediately, even though the throttle is set to low.
Now I can't figure out how to get the Timer to only start when I advance the throttle past the 75% point.
I know the timer can be reset by using the CLEAR function on the screen, but I don't want to use that, or the Trainer Button because I forget to press it before takeoff.
Any ideas?
davidmc36 12-26-2016 11:21 AM
Can you set timer to come on below -75%.....?
Joystick TX 12-31-2016 07:07 PM
No.
DP01 01-01-2017 07:00 AM
Oops
davidmc36 01-01-2017 03:26 PM
Originally Posted by Joystick TX (Post 12291380)
No.
Hmmm, seems odd you can't scroll the numbers the other way and get negative numbers.
AndyKunz 01-07-2017 09:13 AM
Throttle is positive only, IIRC.
Andy
Joystick TX 01-07-2017 03:15 PM
I figured that out. Will try to remember to push the "Clear" button before takeoff.
Later, I'll put a servo in that operates the other way.
Thanks.
