Help with futuba t9chp radio w dft module
Hi everyone,i have a futuba t9chp same almost to 9c radio..recvr. Is pluged in alirons and pitch for left and right turns,both on 140 percent butturns left twice as far as right..is there a fix for this??? Thanx brett
Been a while, but i think you have to move the stick each way to set the travel direction
BARRACUDA JOCKY that sounds more like gyro install,thanx anyway BRETT
I'm sorry but I'm not sure I understand your question. I use a 10C now but used a 9C for many years. Can you clarify any?
David |
your right barracuda,I did move stick both ways,just the one plugged in ail. to 140 percent than i went to pitch which is other side of ail. put that also to 140 percent..But still turns more left than right..So question is can i do anything to turn equally????
It sounds like you've got a mix activated. Do you have any other models in the radio to compare too, or even an open memory slot that's still set to factory default you could plug things into for testing? Just to compare at this point is all. If your functions are equal when set to default, and you go to your model slot and they're off, then again it would likely be a mix that's activated. Just a few thoughts there.
I'm a long time 9C user myself, although it's been quite a while since I've fiddled with mixes, I do remember a few things.. haha... and I still use my 9C a few times a year as well. They're great radios and mine's worked flawlessly for many years. I hope you get yours worked out. |
Thanks d-grant,i'll check mixes thanks brett
Hi,i checked all mixes all inh...still more left than right ail i checked servo in basic menu,and it shows left is twiice as far in left than right,i'm baffled,,.i'm gonna try putting y-harness on pitch to ail. See what happen's any other idea's will be appreciated thanx brett
Did you zero out the sub trim?
David |
HI,Yes all trims,sub trims are on zero,I Even e-mailed futuba-usa,no answer yet,, thanks BRETT
