Spektrum Programmer win11 "core isolation" Issues
I OFFER THIS THREAD FOR INFORMATION ONLY. PERFORM THESE ACTIONS AT YOUR OWN RISK. I ASSUME NO LIABILITY WHATSOEVER.
THIS SUGGESTED FILE WORKED FOR ME, BUT I HAVE NO WAY OF BEING CERTAIN IT WILL WORK FOR YOU. If this has been covered before, my apologies When I downloaded the Spektrum Programmer into my shiny new windows 11 computer, I got a message that the supplied driver would not be loaded due to "core isolation", and I had to disable "core isolation" in order for the driver to load and run. (You can find the "core isolation" settings in device security) I was not comfortable having to disable a safety feature in win11, so I started searching for a solution. The supplied "Horizon Hobbies" driver is an FTDI driver, so I went to the FTDI website and downloaded their latest driver package. It comes in a zipped format. After unzipping it, I was presented with an "application" file to install. I swallowed hard and installed it. I wish I could say that it took care of the problem immediately, however more work was required. I went to device manager and located the "AS3X" that was highlighted yellow (need's attention) it should be located in the USB devices. I opened that line and click on update driver. Then I select "browse my computer for drivers" Next, I clicked on "let me pick from a list of available drivers on my computer". I had to unclick "show compatible hardware" switch. as it was already enabled on my computer. (it's a little box above the list) Next, I scrolled down to "FTDI" and select it. I selected FT4222 Interface A (it was the first choice on my list). When I clicked on "next", I got an "incompatible driver" warning, I answered "YES" That driver loaded, and after a restart of my computer, my Spektrum Programmer worked properly, and I was able to turn the "core isolation" back on. REMEMBER, DO THIS AT YOUR OWN RISK. I ASSUME NO LIABILITY WHATSOEVER. |
Thanks for the information. I only have one computer (out of three) in my home office running Windows 11. Main one used Win10, another Win7.
Microsoft, in cooperation with some software developers, love to kill other software on your system during updates. The key here is not allow Microsoft to automatically update any version of Windows. System settings allows you to be notified of pending updates so you can set a Restore Point prior to updating, thus allowing a roll back if updates muck up some of your software. I have done this several times until finding a work around as you did. By the way, the Spektrum Programmer runs flawlessly on the Win7 machine. Best example of this 'cooperation' is when using Adobe Products. I have used Adobe's Graphics Suites for years during my Desktop Publishing business. To maintain productivity as new versions became available every couple of years, purchasing the next suite version entailed spending $600 and up every time for a packaged licensed version. Then Adobe changes to online subscriptions, no more packaged software. So, after spending $1200 on the last packaged version several years ago, Windows updates has periodically rendered some parts of the suite totally inoperable. Yep, now you have to go the subscription route to use it online. So, set Windows update notifications to give time to set a Restore Point prior to updating. Save the headache of software being rendered obsolete. I will apply your solution to my Win11 machine. |
Moon pie... Thanks! It worked for me. Of course now I have to remove the Driver in order to turn core isolation back on.
This is just another reason I am migrating away from Spectrum. I will never buy another spectrum product again. |
Actually, my computer allows the "Core Protection" to be enabled when I use that FTDI driver.
I can understand your frustration with Spektrum, but be aware, this issue is not unique to Spektrum. Any programming adaptor (Dongle) that uses either the FTDI or Prolific chip seem to have driver issues in Windows. The programming dongle for my Baofeng HT had to have the driver replaced for it to work properly also. The Prolific chip that they use has been around a LONG TIME, and support for it is dwindling. I informed Spektrum about the proper FTDI driver, but they showed little interest in my response as they are now married to the "foreword programming" scheme. |
Originally Posted by Moon Pie
(Post 12790153)
We are fully committed to constantly improving the Programmer product, as it is a core essential for updating receivers (to which we are also highly committed) and some low-end transmitters. Take a look at the newest download. Andy |
windows 11
Does that mean the programmer (3.8) will work on windows 11?
Yes, you just need to tell Win11 to allow the driver to load.
Andy |
(Post 12746449)
They should be interested since you have to be able to register the new receivers and and update the firmware.
