RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   basic receiver set up (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/1212169-basic-receiver-set-up.html)
Hawkeye438 10-19-2003 03:15 AM
Is there a standard for connecting each type servo to a particular receiver channel? Is the throttle always a certain channel?Etc.
Geistware 10-19-2003 06:59 AM
RE: basic receiver set up
Yes, JR and Futaba is different.
Which do you have and someone can tell you the proper channel for each control surface.
Hawkeye438 10-19-2003 08:16 AM
Futaba 9c. Thx.
Geistware 10-19-2003 09:19 PM
On a futaba it is as follows:
Channel 1 - Aileron
Channel 2 - Elevator
Channel 3 - Throttle
Channel 4 - Rudder
Channel 5 - Gear
Channel 6 - Flaps
Channel 7 - Aux 1
Channel 8 - Aux 2
ORIGINAL: Hawkeye438
Futaba 9c. Thx.
Hawkeye438 10-20-2003 04:24 AM
Thanks. Then there must be a mistake in the manuel. I finally found what it said, and it put "aileron" in #5. When I started the basic set up for 4 CH, it then sent me to aileron menu and said activate 5-6 or 6-7. I tried to activate 5-6 but flipped over to 6-7 every time. So I guess if I move aileron to #6, I'll be in business. Thanks, I'll try this in a little while.
amcross 10-20-2003 09:45 AM
Hawk,
You're misreading your manual.
BASIC setup, aileron is 1. this is for ANY model, aileron is always channel 1 for FUTABA.
Now.....USING AILERON DIFFERENTIAL *AND* a 5 channel receiver, the 2nd aileron goes on 5, and you have to change AIL2 to 5&6. ail. diff and a 6+ ch receiver, the second aileron goes in channel 7.
using flaperons with a 6+ channel recever, the second servo goes on channel 6; with a 5 channel, it goes on 5 and you have to change AIL2 to 5&6.
and so on.
Hawkeye438 10-20-2003 09:52 AM
Thanks, I'll try that.
