Hitec Servo Arms?
I'm wanting to get some good aluminum long servo arms for hitec servos and need to know if JR arms or Futaba arms will interchange with them?
Thanks |
Hitec Servo Arms?
I know Futaba won't, but I'm not sure about JR. Since most aftermarket manufacturers such as Dubro identify unique versions for each (JR, Futaba and Hitec), I suspect not.
Hitec Servo Arms?
Unfortunately there is even less servo arm compatibility across manufacturers than there is with frequency shift! You will need to get aluminum arms for Hitec servos. Try Century Helicopters -- they have a good selection of aluminum servo arms.
Cheers! Galen |
Hitec Servo Arms?
Nelson hobbies has lang aluminum servo arms for Hitec servos, but bring lots of money with you.
Vince |
hitec servo arms
I got mine at Air Wild hobbies. They have a sweet design that lowers the output arm and reduces the stress on the output gear and case. They make two different shaft styles to fit the older and newer HITEC servos. I have then on my sig cap and love em.
