PCM 8103
I turn to the Guru's once again. I am converting my 8103 to pcm for turbine---Which 8 ch rx would be best ??? I read you can't run "boosted" extensions on a certain rx,,, I think it was a 549---so maybe the 649. Whats the difference ???
Thanks Rob |
RE: PCM 8103
The 549 is PPM, the 649 is PCM. Above that are the 955 and 945, which are 10 channel (the 945 is dual conversion, the 955 single). And lastly, if you only need 7 channels, there is the new 770.
- Tim |
