RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Just upgrading to digitals????? (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/1596823-just-upgrading-digitals.html)
mattyd 03-06-2004 02:41 PM
Ive just purchased my first set of digitals JR 8411 * 5 . and a 2400 battery pack ive been told i should be looking at recharging between flights. Am not sure what charger to get any tips would be appriciated.
They are currently mounted in a H9 Funtana and also am running a 331 for the throttle
Many Thanks:eek:
AJF--2 03-06-2004 04:15 PM
RE: Just upgrading to digitals?????
NO-NO-NO!!!! You have been told wrong. A 2400 battery running 5 digitial servos should last at least 5 or 6 flights. The 8411s are a bit of overkill on the Funtana though. I run 811s and 5475s on my Lazer 3d with a 1000ma Nimh and after 45 minutes of flying I still have a ton of battery left. Nonetheless-- I always check the battery AFTER EACH FLIGHT---that way they do not have time to recharge before you check them just before the next flight.
mattyd 03-06-2004 05:21 PM
Thanks for that, The reason i got 8411's was they were doing a deal on them in local shop so thought i could use them next year when i get something bigger.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
