RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Bad servo glitching question (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/1598694-bad-servo-glitching-question.html)
In2JeepN 03-07-2004 03:10 AM
Hey guys, I know that most of you here in the radio section are plane guys, and mostly fly in the warm weather etc but I was hoping someone could maybe give me some advice on my glitching problems. I have a JR XS3 computer radio (crystal-less 27M) for my RC truck, and I am having what seems to be bad interference problems. The radio system is only a couple of months old, and just today I put brand new Durcells in the radio, and a brand new 6v hump pack in the truck. Everything tests out fine in the house, no trouble at all, but after only a couple of minutes run time my truck becomes intermittently non-responsive (for a second or two) and then fine for a few seconds etc. I shut the engine off and the problem persists (eliminating vibration). Sometimes it seems almost like lag or delay, but by delay I mean 2 or 3 seconds as well....like I can pin the throttle, and literally count to 2 or 3 before the servo moves. Sometimes its sluggish in movement. Quite often it just twiches around in all directions regardless of what I am telling it to do. I have moved locations all across town. Could this be the cold weather in any way? It's below 0 here, but I have used the truck all winter. When I shut of the TX everything is fine. I have always been careful with my TX and it's never been dropped, but the RX takes a pretty good beating in the truck when we are jumping them etc. Is there any way to test the RX using a meter or anything? Any help would be appreciated.
Lynx 03-07-2004 04:05 PM
RE: Bad servo glitching question
Your best bet on testing the RX is to find someone that has a transmitter on the same frequency that will work with it. The kind of interference you're describing sounds like something faulty in the transmitter, operating the radio in 0 or bellow weather may be causing condensation inside the case once things heat up (the power amplifier gets pretty warm) so try it in a warm environement after it's had time to reach the warm area's tempature (like 2-3 hours after you bring it inside) and see if you can get the problem to happen again.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
