Projeti cut my Antenna
Last week I launched my projeti and it dipped
to the ground and the prop cut the antenna wire in too. good thing i brought it back around close so i could check it. I soldered the wire back together and put that radio in my lil rascal and put a new hitec 555 in the Projeti, today I cut the antenna again (Not gonna run it back under the prop a third time) but the last 20 - 30 inchs of the antenna are gone nowhere to be found, what type of wire could i use to make a whole new antenna?? and what length? or do i need to send it back to hitec? I'm ok at soldering so I dont mind doing it myself, thinking of trying one of those little base loaded antenna's they use on jets and helicopters anyone have any luck with resoldering the wires or the short antenna's?? Thanks |
RE: Projeti cut my Antenna
Any type of small diameter high strand count wire.
Just make sure that the length is 39.4 inches. |
Thanks, also is the 39.4 inches from the solder pad
or where it exits the case? ORIGINAL: Geistware Any type of small diameter high strand count wire. Just make sure that the length is 39.4 inches. |
It doesn't have to be exact, don't worry about it.
