RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   JR 8103 gimbal stick tension (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/1603170-jr-8103-gimbal-stick-tension.html)
Jack28 03-08-2004 12:58 PM
Does any one out there know about a different spring for better gimbal stick tension on the JR 8103. Mine is about 4 years old and I want the stick tension to be tighter. I have already adjusted the tension but it still is not to my liking. Someone told me there is a spring that the pattern guys use , I think it was an spring from a 9 channel single stick radio that JR used to make, I called JR and they did not have a part number. Any help would be appreciated, Thanks Jack.
dsnyder 03-08-2004 02:01 PM
RE: JR 8103 gimbal stick tension
We have some stiffer springs available, however we do not sell JR repair parts due to liability reasons. You can send the radio system in and have the springs changed.
Lynx 03-08-2004 07:49 PM
They're just springs, take one out and bring it to a hardware store and see if you can find anything that's close enough to the same size and stiffer.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
