futaba 9cap
I have just recently purchased a futaba 9cap, for airoplanes, transmitter came with low band chrystal, and module, but I really have know knowledge on what reciever I need to purchase for this unit, It has been years since I have used one of these. I am curently in the prosess of building a top flite giant scale corsair. Could anyone tell me of what type of reciever is needed, some series are fp 149dp, or r149dp, or do I even need a 9 channel reciever, I am confussed, just need a little heads up before I make the purchase!
Thanks D M |
RE: futaba 9cap
I also recently purchased a 9CAP for airplanes. The receiver mine came with is a R149DP. The 9CAP can transmit FM or PCM so you could also use a FM receiver. I think the FM receivers only do 8 channels but the PCM receivers do all 9 channels.
Kris |
RE: futaba 9cap
Do yourself a favor and get the 149DP on the low band!The reciever is PCM which is a digital type signal.the analog vertion is called a 149df.Unlimited mixing possibilities with the 149DP and the 9CAP!!!
RE: futaba 9cap
You can use any futaba receiver that is on the same frequency as the transmitter (except some of the very old models)
Some I would recommend are: R127DF R138DP R148DF R148DP R149DP R309DS |
RE: futaba 9cap
Hey Geist, are you sure about using the 309DS RX on a 9C? I thought it was only used for the programmable 9Z
RE: futaba 9cap
I use the Hitec Electron 6 reciever due to its' small size and light weight with my 9c.
RE: futaba 9cap
You can select the transmitter channel on the receiver and it will work.
WHile the receiver will still work on other channels, it will only work on one channel with a single channel transmitter. |
RE: futaba 9cap
also, that extra channel you get on pcm is only a binary one, no proportional control, so it is of limited use, basically smoke or gear only.
RE: futaba 9cap
I use a GWS on my shocky with my 9C :D And an ECubed antenna.
RE: futaba 9cap
What is an ECubed antennae?
ORIGINAL: 3DFanatic I use a GWS on my shocky with my 9C :D And an ECubed antenna. |
RE: futaba 9cap
It's a loaded antenna that's only about 6 inches long. Easy to hide in my shocky.
RE: futaba 9cap
OK, if this is a whip antennae, I have used them and like them.
