RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   How can I hook two elevator servos together (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/1641478-how-can-i-hook-two-elevator-servos-together.html)
mnrcaerobat 03-19-2004 07:11 PM
I am trying to use two elevator servos on my next plane. I soldered them together and the servos go in opposite directions. I tried switching the red and black wires, and that didn't work.
Flying Cowboy 03-19-2004 07:40 PM
RE: How can I hook two elevator servos together
A few years ago, when the servos were made withe wires between the pot and the circuit and the motor, it was possible to reverse the rotation of a servo but now you have to buy a servo reverser to change the rotation of a servo.
If you want to connect two servos on elevator, you need a servo that rotates on the wrong direction. (Some are available but not all)
You could use the servos that you have but connecting the two push rods to the same side of the servo arm.
mnrcaerobat 03-19-2004 10:38 PM
mnrcaerobat 03-19-2004 10:40 PM
Sorry for the double post. I made it work with a bellcrank. Used a piece of 5/32" music wire, three nylon steering arms, and two wheel collars and it looks like it will work well.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
