Slave on 7C or XP6102?
I'm thinking of buying one of these two systems and am wondering if I can "bind" the two elevator servos together so that they move exactly the same amount? If so, what channel is used for the second elevator servo? Thanks for any info.
Dan |
RE: Slave on 7C or XP6102?
It is possible. On the 7C the channels should be channels 2 & 7. Use the Ailevatar mix.
Beware that by accounts so far the gotchya on these radios is that the trim will not move both halves, 'bout as usefull as those things on a boar pig if you ask me :eek: Futaba may break under the pressure if rumour has it and release a proper firmware to make this an operable feature.
I was misstaken on the trim for dual servo setups.........I may send my system back. Not being able to tirm the slave servo.....is going to be a problem.
Othher than that feature missing....its a great system overall. |
Thanks for the info. Looks like I'll be keeping what I have for now.
Dan |
