I WANNA SMASH IT!!!!!!!!!!!!!
I really do!!!! OK.... I have a Super 8 Futaba Radio(8uaps) and I cannot get the second elevator servo programmed.... I have a Katana with dual elevator servos... I am trying to program the second servo and no matter what I try I just cant get it right.... I was told to use the Ailevator function..... I have the Higley book but it doesnt use plain english nor does the Futaba manual...... Someone PLEASE tell me in ENGLISH which channels to use and how to make it all work WITHOUT having to have the second servo dialed in just right on the channel knobs on the radio... THIS IS REALLY DRIVIN ME NUCKIN FUTZ...... I had a 9ZAP back in the early 90s and it was WAY easier to program than this thing..... HELP!!!!
Myron |
RE: I WANNA SMASH IT!!!!!!!!!!!!!
This is how mine are set up channels 1 and 6
Flaperon ail 1 +100 +100 ail 2 +100 +100 Flp2 +100 Flp 1 -100 Ailevator ail 3 0% ail 4 0% ele2 -100 ele1 +100 |
Wait wait...HAD???
Thanks guys,
I think I got it BUT... On high rates with max travel on the servos I can rock the stick back and fourth real fast and the servos just dont seem to be in sync..... If I rock the stick slow they seem fine.... I do have my exponentials set up on high and low rates. I am using futaba 3001's and a 6 volt battery and the second servo on #8 channel.... Yes, all the servo arms and horns and linkages are set exactly the same..... I should have NEVER sold my 9ZAP!!!!..... Redrum, Are you flying a large IMAC type model? Which one? By looking at your programing you are usings your ailerons as flaps right? If so, how does you model act when deployed? I am flying a Katana that weighs 11lbs4oz and its wing loading is pretty light so she lands pretty slow.. Just wondering how it would act if I re-programmed more like your set up... Myron |
I just discovered a problem on a 9zwII, Somehow I had atv & afr set to 140 (both). Do not do this! Weird things will happen! believe me. I almost went nutz and sent it back.
You might see a slower response on the higher channel servo i read somewhere that it can be seen on the higher channels Ie radio commands 1 fist then lastly 8. Could it also be the servos??
Myron..I am flying a GP Extra 300 with a Saito 1.20...I can get it to do a harrier and elevator with the spoilerons up..I really dont use the flap option
When mixing channels that are several channels apart, such as #2 and #6 or 7 for dual elevator servos, the higher-humbered channel will lag a bit. That's because it's control signal comes slightly later in the pulse train. You can see it when you make sudden movements of the sticks, but you won't really see any effect on the model in the air.
Bill quick quesiton. Do you mean it will not affect the flight of an airplane, or maybe alittle bit. Just wanted to know since I will be starting IMAC.
The model's flight won't be affected. R/C systems have had these issues ever since mixers were introduced. There will always be some delay until higher data rates can be achieved in sending control information from the transmitter to the receiver. Then the delay will be so small that it'll be imperceptible.
Thanx BAX
