Sheilded cable
HI all , can anyone see a problem arising with 20 gage 2 wire shielded plus on the outside of the shield, a ground wire. I have been using this cable for extensions up to 36" for quite a while now with JR PCM receivers and have never had a problem. I"m going to some 48" extensions so this is why I ask the question.
Rcpete |
RE: Sheilded cable
Is it much heavier?
RE: Sheilded cable
I don't see a problem with doing it this way. All I would want to ask is why?
RE: Sheilded cable
HI Dirtybird, do you know a better way, I personally do not like having connections, so I usually cut the lead off the servo and run a new cable the exact lenght back to the receiver.I have a spool of 2 wire shielded cable,it has the ground between the shield and the outer covering, maybe I should get some 3 wire and join the black and ground at the receiver like I"ve read on other posts. Can some of you electrial experts chime in on this post.
Rcpete |
RE: Sheilded cable
HI, will the shielded cable stop some of the RF noise.
Rcpete |
RE: Sheilded cable
Why not just use the shield as the third wire? The shield needs to be connected to the negative somewhere. Might as well use it.
