3 amp fuse for jr Radio
What volt 3 amp fuse is used in JR Radios 125v or 250v . I threw the one I blew up away befor I looked at it DUMB I know.
RE: 3 amp fuse for jr Radio
It doesnt matter about the voltage, its the AMPs that matter, the radio operates on less than 12 volts.
It is the shorter type glass fuse but the longer ones work if you bend out the little metal end tabs. |
