Futaba 9Z wc2 Failsafe Question
Does anyone know about the programable dealy on the failsafe feature that the 9Z wc2 transmitter uses?
Thanks in advance |
RE: Futaba 9Z wc2 Failsafe Question
umm, what about it? it is standard pcm failsafe... (most of the failsafe stuff is done in the pcm rx, not the tx. the tx only tells the rx what to do, the rx still needs to process and figure out if it should go into failsafe or not)
