E-Flite Blade Cp Parts needed
I need a 4-in1 unit for my Blade Cp. I can't find anyone or anyplace with this. Everyone that sells parts for this doesn't list this part for some reason. This is what happens when you go inverted with a Li-Po pack with out upgrading the stock motor. I wsmoked the stock one and then I replaced it with the newer one with a heat-sink, but found out that I wasted the 4-in-1.
RE: E-Flite Blade Cp Parts needed
www.horizonhobby.com has it, so does www.hobbyzone.com . I just got my CP, made contact with the ground after a 40 foot drop, but my electronics are intact. Both of them have it for 69.99 I Believe. Good luck.
