Connector crimpers
Has anyone ever bought one of the connector kits that has a crimper and male and female connectors that you can use to make up your own aileron extensions, charger pigtails, etc?
Thanks! JLK |
RE: Connector crimpers
on board
Yes, www.radicalrc.com You buy the crimping tool, connectors, and wire separately. He has them all.
JP,
I just looked and found all kinds of neat stuff put I couldn't find the crimpers or the "blank" connectors... JLK |
ORIGINAL: jlkonn Has anyone ever bought one of the connector kits that has a crimper and male and female connectors that you can use to make up your own aileron extensions, charger pigtails, etc? Thanks! JLK |
The right crimpers for the job are paramount IMO, you'll find many available for the task some better than others. Professionals in this industry use crimpers that cost thousands of dollars there is a HUGE difference...
Special thanks to Simon Van Leeuwen for the effort to compile the following information: Picked from inventory PN's that can be readily purchased from Digi Key, Electrosonic, Newark, Allied Electronics and be on your doorstep next day. Digi Key is probably the best in the shipping area; they have a next-day flat rate to your door): REPLACEMENT 0.100" SPACING MALE/FEMALE CONNECTORS NOTE: These housings, spring contacts, and pins will accommodate up to 20awg and feature a locking detent which means they will only physically separate if you unlock them (nice feature). Will handle 4.5A all day. Description PN Comments receptacle 104257-2 crimp spring contact 104480-9 30u" Gold, loose plug 103653-2 crimp pin 104505-7 30u" Gold, loose GENERIC 0.100" 3 PIN FEMALE CONNECTORS NOTE: These were chosen to fit all receivers, so they are not keyed. Description PN Comments plug, 3 position 530554-2 crimp spring contact 531224-7 30u" Gold, loose HEAVY DUTY LARGE SCALE 3 PIN CONNECTORS option #1 NOTE: These, and the following series, are readily available high-performance connectors able to handle in excess of 5A, yet are small and lightweight. Description PN Comments Receptacle 43645-0300 3 position (up to 12 pos avail) crimp spring contact 43030-0009 30u" Gold, 20-24awg, loose plug 43640-0301 3 position (up to 12 pos avail) crimp pin 43031-0003 30u" Gold, 20-24awg, loose HEAVY DUTY LARGE SCALE 3 PIN CONNECTORS option #2 NOTE: Not quite so readily available but are slightly smaller and higher performance. These are liquid proof, and offer detent friction lock mechanisms. Description PN Comments Receptacle 52213-0311 3 position (4 pos avail) crimp spring contact 50148-8100 Phosphor Bronze, 20-22awg, loose Plug 52266-0311 3 position (4 pos avail) crimp pin 50147-8100 Phosphor Bronze, 20-22awg, loose SPECIAL APPLICATION PLUG-AND-PLAY SYSTEMS Description PN Comments Plug, 8 position 172063-1 Receptacle, 8 pos 172070-1 Spring contact 170311-1 both housings use same contact HIGH PERFORMANCE HOOK-UP WIRE NOTE: Alpha 19/34 (19 strands of 34awg) TEFLON jacketed multi-color lead which is service-rated to 13 amps continuous (single lead, free air @ 30C ambient). TEFLON also offers the least mass of all the available jacket materials for weight critical applications such as F3B/F/J style aircraft. You can cut costs by choosing to buy regular PVC jacketed lead, but the performance specs drop off accordingly (8A max, increased jacket mass, bulkier). You will see a PN for this material as well. The PN's essentially remain the same, except that the color code changes. Replace "RD" with the color of your choice (black-BK, white=WH, etc). Description PN Comments Red, 22awg, 19/32 5855RD005 TEFLON jacket, 100ft roll Red, 22awg, 19/32 1855/19RD005 PVC jacket, 100ft roll Finally one caveat, an onboard control system is only as good as its weakest link...electrically AND mechanically. The above systems rely on proper crimping procedures (amongst other things) to ensure rated specs and mechanical integrity. Don't fool yourself, improper crimping is just as catastrophic as improper soldering. |
ORIGINAL: mglavin The right crimpers for the job are paramount IMO, you'll find many available for the task some better than others. Professionals in this industry use crimpers that cost thousands of dollars there is a HUGE difference... <snip> Finally one caveat, an onboard control system is only as good as its weakest link...electrically AND mechanically. The above systems rely on proper crimping procedures (amongst other things) to ensure rated specs and mechanical integrity. Don't fool yourself, improper crimping is just as catastrophic as improper soldering. It is VERY easy to crimp these tiny connectors improperly. One especially easy error is putting too much pressure on the pin at the insulated section of the wire and cutting the wire inside the insulation, that's what I did... :eek: If you are going to make your own leads, it would be a good idea to at least check them for continuity while flexing the lead with a multimeter if you can't load test them which would be best. |
http://rc-dymond.com/
Try this, been using there pin sets for years with no issues. Have also used pin sets from everyone else. I've made too many of these extensions for there to be a problem with this product. The crimper plyers work great....Very resonably priced, The only problem I've ever encountered with any extension is from pulling on the wire itself to remove or unplug an extension, servo or whatever. These plug and unplug securely as well as any. I have only used 22 ga wire max with these pin sets. 20ga. will go but its tuff to install the pins in its housing...Walt |
