futaba 7c crow config programming
can someone please guide me on how to program crow in my giant stick?? i have a 7c the newer 7ch futaba radio and a 7ch receiver.
thx |
RE: futaba 7c crow config programming
Dunno about a giant stick.... However, for some guide to what you might need try downloading Hangar 9's manual for its Ultrastick. You'll find it at:-
http://www.horizonhobby.com/Shop/ByC...ProdID=HAN2325 This talks about crow programming for various types of transmitters. Might be a start for you? Good luck Runway |
This should help from Futaba's web site 7C FAQ section.
[link]http://www.futabarc.com/faq/faq-7c-q774.html[/link] Phil in MN[8D] |
thank you guys
this is pretty simple to do . you need two programable mixes. set your ailerons up with the flaperon mode. you then turn your airbrake function on and adjust the elevator and ailerons in the flaperon mode. then you use two mixes to mix your two flap channels to the same switch and position that turns on the airbrake function on which should be the three position switch in the full back position.
