overnight charging rate for nimh batt???
hi
i've just got this charger where i can set the charge rate. i want to charge my 2300 mah and 1800 mah nimh batteries for overnight charge. what do i set my charging rate at? thanks |
RE: overnight charging rate for nimh batt???
sorry..... got the wrong forum:)
Depends on what kind of battery you have.
Motor battery? 1-1.5C is typical. TX/RX battery Typically 1/10C |
Motor battery? 1-1.5C is typical. John Sorry couldn't resist. Battery Capacity / Rate of Charge = Time so a C/10 charge is always over night -> 14 to 16 hours |
To get the most out of your NiMh you need to do the forming charge. As Mr. Norton said, 0.1C for 14 to 16 hours followed by a discharge to 0.9 to 1 volt/cell at 0.25C. It may take three or four such cycles before the battery is at full capacity. It is also a good practice to redo the forming charge if the battery has been sitting for a month or two unused and, if you do much fast charging, every 20th charge or so at the 0.1C rate for 16 hours is almost sure to help.
