Futaba and Graupner?
Can I use Graupner servos with Futaba or Hitec TX/RX?
RE: Futaba and Graupner?
Probably, most modern servos are wired the same. Take a look at the wiring, if the ground and red wires line up you should be fine.
Sounds good!
I'd like to try the DS8077s, but all my equipment is either Futaba or Hitec... |
