RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Hitec Flash 5 Programming (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/453708-hitec-flash-5-programming.html)
dratche 01-02-2003 02:17 AM
#1. I cant seem to get the trim to work at all on my Flash 5 Throttle Channel. The other channels adjust fine though. Anybody else have this problem?
#2. I recently tried to mix aileron and rudder on this radio but ran into problems. When I programmed in positive numbers it would work only in one direction. In other words, when I gave it right aileron the rudder would also move right. But when I gave it left aileron the rudder did not respond. Programming in negative numbers had the opposite effect.
:confused:
Eliot
GWebb 01-02-2003 04:05 AM
Eliot,
Try this link.....Greg
http://msinow.com/rc/hitec_flash_5_owners_read_this.htm
David Cutler 01-02-2003 04:16 AM
1/ The throttle trim only works if you are in the bottom half of the throttle movement. Try moving the stick to the lowest throttle position, then setting it at 25 so that you can have about 25 steps each way.
2/ The mix is different for each direction. You have to set the mix for both the directions by moving the stick in the direction you want, then setting the mix percentage, before moving it in the other direction to set that mix. It's so you can mix, say, up elevator for both left and right rudder etc.
David C
