futaba servo
can i use futaba servo to Jr radio? coz no body use jr radio in my area and i cant find local hobby shop who sell jr product.
thanks... |
RE: futaba servo
yes...you can mix and match servos.. as long as the wires are plugged in with the correct polarity, you are fine
RE: futaba servo
The only thing you'll need to do is to trim off the small tab that will be on the side of the plug with the Futaba. JR doesn't use them so your rx won't have a slot for that tab to go into.
Then as noted, it just has to be put in to the rx in the correct orientation, IIRC, it will be the white wire on top of an end loader or closest to the rx on a top loader. Don't worry about getting it wrong as the hot lead is center with the ground and signal lead on each side, so if you plug it in wrong it just won't work but it won't hurt anything. Just take it out and turn it over... ;) |
