Advice on Servos 1.2/1.4 size plane
Hello all,
I am planning to go for a 1.2/1.4 3D plane with an AuW of 12lbs or so. As I make my list of stuff I want to know what are best servos in terms of cost i can use. Dont want to go overboard at all. Want reliable and tested servos that are the cheapest usable. Thanks for all the advice AVF |
RE: Advice on Servos 1.2/1.4 size plane
The Hitec 5645MG's are an excellent choice if you are looking for performance vs. cost. They are well proven and sell for about $55ea.
Mike |
costwise- the new JRSport series are excellent - the 125 is a metal gear train and gear slop on the ones I have been running - remains zero - even after switching from the Funtana to the 33% EDGE 125 inchounces of torque
these go over the counter for about 35 bucks On that size plane - they are really overkill -- the new JR digitals are about same money - less torque but terrific center and smoothness - special plastic gear train- Frankly the servos available all over the market for 35 bucks or so are far far better than the 100 dollar stuff of just a few years back |
$55 is really expensive :( especially coming from 4 servos for $55 :)
Dick can those JR servos be used with Futaba ? Thx AVF |
will they fit the connectors?
yes Some JR servos have very tight dead band and if used on Y's with one reverser and some other setups - they can get antsy but if the system is properly laid out - the $30.00 MAP price 821 -for example should perform properly . These have 72 inch ounces of torque at 4.8 v and are far better than servos we used in much larger aerobatic competition models in the 1990's 40 inch ounce was the standard then For your size model - these should work even with fairly extreme throws. I use 5 cell rx packs which boost power - 15%- roughly Most setups where servo power and performance is bad - are simply not properly setup . By using full servo rotation and well operating control linkages (not expensive - just smooth no binding ) servos with lower advertised power can do extremely well . |
