changing an AM crystal in a dual conversion
can I swap another crystal number in my AM dual conversion receiver its now 48 and I wanted to use channel 24 from a hitech AM single conversion receiver crystal or is there no such thing as a single and dual crystal
RE: changing an AM crystal in a dual conversion
Use a crystal made for your dual conversion receiver. A single conversion crystal will probably not work.
No, a single conversion crystal is usually 455KH different from the channel frequecy while a dual conversion crystal is about 11.7MH different.
ORIGINAL: pettit Use a crystal made for your dual conversion receiver. A single conversion crystal will probably not work. |
There is probably no difference between AM and FM crystals,if both are dual conversion.If the receiver is "Dal Conversion",it definately needs a "Dual Conversion'crystal though.
ORIGINAL: KB9STD There is probably no difference between AM and FM crystals,if both are dual conversion.If the receiver is "Dal Conversion",it definately needs a "Dual Conversion'crystal though. Thanks for the information |
