What glue for MC24 potentiometer?
Hello,
I have an MC24 and I think that I need to adjust the rudder potentiometer. I was wondering if somebody can recommend a glue that I can use to reglue the potentiometer once I have done the adjustment? I would like to be able to get it at home depot or walmart, etc... I read that I need to use a neoprene glue but I don't know what glue meets that description[sm=red_smile.gif] Also, any tips on how to perform the adjustment? Thanks a lot, Le fou |
RE: What glue for MC24 potentiometer?
To adjust..... this is how I do it on all the JR sets I get in.
Select an unused model memory, carry out a model reset, use DSC to a receiver with only the rudder servo fitted. Use servo reversing feature to toggle between normal and reverse whilst watching the servo. Make small adjustments each time until the servo no longers moves when you toggle the reversing function. Glue and wait. Once set, repeat to validate the position. |
Hello Mac_Man_UK,
Thank you for your reply. What kind of glue do you use? I want to make sure that it does not attack the plastic. Do you have any suggestions? Thanks, Le fou |
On this side of the pond, I use Evostick. Its fairly fast setting.
