split elevators r127df / 9c
I have elevators plugged into 2 and 7, and am using pmix2. All is fine until I go to hi rate or from lo to hi rate - the travel is off by 1/4 inch or more. What is the proper way to set up split elevators when using a 7 channel receiver with a 9c tx. The plane is flyable as long as I set up lo and hi rate percent to be the same.
thanks, Mike |
RE: split elevators r127df / 9c
ORIGINAL: kneewhack I have elevators plugged into 2 and 7, and am using pmix2. All is fine until I go to hi rate or from lo to hi rate - the travel is off by 1/4 inch or more. What is the proper way to set up split elevators when using a 7 channel receiver with a 9c tx. The plane is flyable as long as I set up lo and hi rate percent to be the same. thanks, Mike Recheck geometry as well as radio end points & D/R. Make sure that you are using full travel in the radio and not turning the EPA or D/R down to get the desired travel... use the mechanical linkage for with the shortest servo arm possible. [If possible, the control horn length on the surface should 1:1 with the servo horn]. Check both halves travel full distances equally on a Y lead in one channel, so as to maximize mechanical and electronic advantage for the servo, then try with your separate pmix. Low EPA/D/R do affect the centering capabilities of any servo. If above does not assist then the TX requires recalibration. Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
| All times are GMT -8. The time now is 12:02 AM. |
