Changing Crystal On TX
Tell me is it safe to change crystals on transmitters. Like go from one channel to another.
Thanks, Mike |
RE: Changing Crystal On TX
ORIGINAL: Jerkey Tell me is it safe to change crystals on transmitters. Like go from one channel to another. Thanks, Mike 1. RC system in use? 2. Regulations and penalties pertaining to the country in which the system is being used? Subject is well covered in sticky FAQ - Transmitter crystal swapping (USA) Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
Its illegal and unsafe.
It is illegal in the USA but not in some countries, check your local laws. It can be unsafe in any area as different brands of transmitters may require different types of crystal even when the frequency is the same due to type of oscillator design. Does it require Xcut or Ycut crystals, does it use 3rd or 5th overtones etc. Also, since crystal are usually a piece of quartz ground to specific mechanical size, there will always be slight variations between similarly marked crystal requiring that the crystal be pulled (adjust the LC circuitry of the oscillator) to bring it right on frequency.
He's from Illinois, that makes it illegal. Case closed. IF he has a MODULE based system it is legal and safe for him to swap complete modules.
Whenever changing a RX crystal (legal in all cases) best to use a crystal from the original manufacturer. |
Unless he has a Multiplex crystal based radio, since those are certified and legal (in the US too . . ) for end-user crystal changes. It all depends on how the Mfg. got the radio certified . . .
All the rest, by todays technology, should be totally safe to swap, but that doesn't get past the burocratic B/S prohibiting changes in the US. The same basic modules are magically safe and legal to change in other countries . . . The power levels in R/C are so low, that the current brand of modules are broad-band enough that I doubt that even the factory tunes them when they load a crystal - they most likely just peak 'em up in the center of the band. - Tim ORIGINAL: bruce88123 He's from Illinois, that makes it illegal. Case closed. IF he has a MODULE based system it is legal and safe for him to swap complete modules. Whenever changing a RX crystal (legal in all cases) best to use a crystal from the original manufacturer. |
Works fine changing the crystal. Know a guy that's been doing it for years. Not a hint of a problem. Don't worry about it.:D
Unfortunately MrBigg won't be paying the 10 grand per occurance fine so 20 or 30 bucks to do it right is cheap.
ORIGINAL: BarracudaHockey Unfortunately MrBigg won't be paying the 10 grand per occurance fine so 20 or 30 bucks to do it right is cheap. |
ORIGINAL: BarracudaHockey Unfortunately MrBigg won't be paying the 10 grand per occurance fine so 20 or 30 bucks to do it right is cheap. Why would I be paying the fine? I didn't say that I do it. You just assumed it. From what I've witnessed, there is no problems at all swapping crystals and I encourge everyone to try it and see for your self. Do it at home away from the field. Do some range tests. Use a gasser with a magneto ignition. Then check your frequencies with one of those frequency checkers. You'll see that the crystal you swapped out is not jumping in between channels like some people might have you believe.:D |
ORIGINAL: Eplane65 ORIGINAL: BarracudaHockey Unfortunately MrBigg won't be paying the 10 grand per occurance fine so 20 or 30 bucks to do it right is cheap. |
I've tested out changing a transmitter crystal and it worked fine as long as your original crystal is the same band as the new crystal. I believe low band is like ch 1-30 and high band is 30-50. I certainly don't condone it, but it works.
I would also like to add that I swapped crystals for a total of like 10 minutes just to test it, out of curiousity.:D I'm personally just going to move to spread spektrum and be done with it. |
The problem arise from those companies that PAY to use the channels in between the channels assigned to modellers. If they start getting interference from you and your transmitter, you can guarantee that they will complain to the FCC. As they are paying customers, don't you think somebody would start looking at the cause ??
Remember that they are only 10KHz away from you, if your original crystal is off frequency (as they can be quite easily), the deviation adjustments will bring it back on frequency. You then change the crystal for one that happens to be spot on freq, no unless the deviation is readjusted, those initial offset adjustments (for the old crystal) can easily cause you to be off frequency and splattering into adjacent channels. |
ORIGINAL: mrbigg ORIGINAL: BarracudaHockey Unfortunately MrBigg won't be paying the 10 grand per occurance fine so 20 or 30 bucks to do it right is cheap. Why would I be paying the fine? I didn't say that I do it. You just assumed it. From what I've witnessed, there is no problems at all swapping crystals and I encourge everyone to try it and see for your self. Do it at home away from the field. Do some range tests. Use a gasser with a magneto ignition. Then check your frequencies with one of those frequency checkers. You'll see that the crystal you swapped out is not jumping in between channels like some people might have you believe.:D First, we SHARE the 72 mhz band with other users. If your transmitter bleeds over onto a shared frequency, there's a risk of interfering with them. A field frequency checker WILL NOT CATCH THIS. If we routinely start causing such interference, at some point, the FCC WILL do something about it. And when they have to choose between irresponsible people playing with toys who can't follow the rules, and business users, guess who will lose. Second, interference is not the only problem. This winter I sent a second hand transmitter to Radio South that I picked up from someone else. The original owner had changed the crystal to a different frequency. I got a phone call from them explaining that due to the crystal swap the power output was only 50%. Tuning brought it back up to 100%. I don't know about you, but I sure as hell don't want to be flying my planes with my radio at 50% power output. Given these things, it's hard to understand why anyone would be irresponsible enough to advocate changing crystals without sending the transmitter in to be checked and tuned. |
It bothers me to see so many people not complying with the law and in some case advocating the noncompliance. In most cases, I think it is just ignorance on their part in not understanding the consequences. They figure just because they get by with it, it is okay to cause others problems or, in some cases, large monetary losses. I guess this is the same mentality that causes them to drive drunk or speeds on crowded highways. It is to bad they can not take the time to educate themselves on the consequences.
What Chuck and Rodney said are exactly the point I was making.
Who has the channels in between our channels?
72 - 73 MHz
# Private land mobile fixed operation [90.257(a)] # Special Industrial, Manufacturers, Forest Prducts, Railroad and Fire Radio Services, mobile operation, 1 watt max. [90.257(b)] # Public land mobile control and repeater stations [22.591] # Radio control: model aircraft [95.207(a)(2)] # Aviation Services - Operational Fixed Stations [87.449] # Auditory assistance devices, 80 millivolts meter max. [15.237] |
ORIGINAL: mrbigg Who has the channels in between our channels? Rafael |
ORIGINAL: Rafael23cc ORIGINAL: mrbigg Who has the channels in between our channels? Rafael |
ORIGINAL: HeaterMan 72 - 73 MHz # Private land mobile fixed operation [90.257(a)] # Special Industrial, Manufacturers, Forest Prducts, Railroad and Fire Radio Services, mobile operation, 1 watt max. [90.257(b)] # Public land mobile control and repeater stations [22.591] # Radio control: model aircraft [95.207(a)(2)] # Aviation Services - Operational Fixed Stations [87.449] # Auditory assistance devices, 80 millivolts meter max. [15.237] |
ORIGINAL: mrbigg ORIGINAL: Rafael23cc ORIGINAL: mrbigg Who has the channels in between our channels? Rafael |
ORIGINAL: mrbigg ORIGINAL: HeaterMan 72 - 73 MHz # Private land mobile fixed operation [90.257(a)] # Special Industrial, Manufacturers, Forest Prducts, Railroad and Fire Radio Services, mobile operation, 1 watt max. [90.257(b)] # Public land mobile control and repeater stations [22.591] # Radio control: model aircraft [95.207(a)(2)] # Aviation Services - Operational Fixed Stations [87.449] # Auditory assistance devices, 80 millivolts meter max. [15.237] Say someone has a radio that was factory shipped with channel 30. Then they swap crystals to channel 31. They get NO bleed over to 30 or 32. How are they going to "bleed" over to a frequency that is further away? If the radio isn't tuned properly, it could bleed to a number of different frequencies besides these. But again, why does it matter WHERE they are going to bleed? The FCC regs require that WE send our transmitters to a qualified person for crystal changes. They will ensure that the transmitter doesn't bleed ANYWHERE, thereby ensuring that EVERYONE is safe. |
ORIGINAL: piper_chuck ORIGINAL: mrbigg ORIGINAL: Rafael23cc ORIGINAL: mrbigg Who has the channels in between our channels? Rafael Wow, you amaze me. You're calling me a troll because I'm asking questions? Thanks alot. Go look at some of my other posts and you'll see that I don't come here to cause trouble and I resent the fact that you are saying that is why I'm here. What I want to know is whether or not there is a legit reason not to change crystals or has a ban been put in place by the government because they know a few "idiots" will have forgotten that they changed frequencies and will bring potential harm to themselves or others. That's all I want to know. |
I don't think the FCC cares a whit about what you do to yourself. What they care about is interference with someone who has paid them for the use of a frequency.
