whats up ?
I have a charge jack on a plane but the funny thing is it seems to charge ok but when I put the checker on it it dosent register at all. I have used the checker on other planes and it works ok. What gives?
RE: whats up ?
G'day Mate,
Are you using the checker, the right way round, in other words, is it the right polarity? Also, make sure you are checking between positive & negitive, & not positive or negitive to the signal wire, this will give no indication. |
RE: whats up ?
This may sound pretty basic, but is the aircraft switch off when you are checking the battery?
RE: whats up ?
ORIGINAL: the pope I have a charge jack on a plane but the funny thing is it seems to charge ok but when I put the checker on it it dosent register at all. I have used the checker on other planes and it works ok. What gives? Rafael |
RE: whats up ?
Thanks all , the charger showed a charge was going in and it turned off when it was charged. After talking with a flying bud who said it has to be either the battery or switch (which made sense even to me) I pulled the battery and it checked ok with the checker, I switched switches and bugger me alls aok again .So it was a dodgy switch which has found a new home in the bin. Thanks for your suggestions. cheers the pope
