Futaba 7 channel 2.4Ghz receivers
Futaba lists two 7-channel FASST 2.4Ghz receivers over at Tower Hobbies which look identical except for the model numbers. One is a R607FS and the other is a R617FS. All of the specs including dimensions appear the same. The R607FS is $5.00 cheaper. Does anyone know if there are any differences in these? Seems odd...
http://www2.towerhobbies.com/cgi-bin...SM&C=LDM&V=FUT Jesse |
RE: Futaba 7 channel 2.4Ghz receivers
Never mind,
I just found this over at the Futaba posts: http://2.4gigahertz.com/faq/faq-fasst-q926.html Jesse |
