How much torque for a 120 sized plane?
Guys,
I'm about to purchase a 120 (two stroke) sized plane. Maybe an Edge, Cap232, or Giles. I would like to know if using Hitec 475HB servos with 61oz of torque @4.8V would be enough? Or I could use 6.0V to get 76oz of torque out of them. What do these planes generally require as far as torque goes? Thanks fellas. |
Paull,
It really depends upon the plane, control surface size, etc. I'd really recommend you ask the kit's manufacturer to be sure. Given your talking aerobats, I would generally like to see at least 75 in oz on the tail; the ailerons can be lower torque in the 50-60 range, and throttle of course can be less still. |
