RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   X9303 Aileron Differential (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/6918551-x9303-aileron-differential.html)
PJ_TankPilot 01-16-2008 06:30 PM
First conversion with aileron differential.
Wing Type Flaperon
JR R921 RX
Left Aileron plugged into Aux1
When I dial in aileron differential, it only affects the right aileron, the left still has full throw both directions.
tail strike 01-16-2008 06:40 PM
RE: X9303 Aileron Differential
ORIGINAL: PJ_TankPilot
Wing Type Flaperon
JR R921 RX
Hmmmmm thats exactly how I set up my 921 worked prefectly.
Don't know what to tell you.
Wlouigene 01-16-2008 08:27 PM
I don’t think you mix them properly
Wing Type
Next, go in SYSTEM MENU, Jog down to DeviceSEL and make sure all switches and channels are set to INH. Return to the main SYSTEM Menu and select Wing TYPE. Set the wing type to flaperon. This will automatically mix the Aileron channel and Flap (Aux. 1) channel. Plug the right Aileron into the Aileron channel (Ch2) and plug the left Aileron servo into the FLAP or AUX1 channel (Ch6) of the RX the radio will now refer to these channels as LAI and RAI. This allows us to adjust the centering (sub trim), direction, and travel endpoints of each aileron separately. Once we have set up the wing type, it's time to hook up the aileron servo linkages and set up the directions, centering and travel.
PJ_TankPilot 01-17-2008 10:57 AM
ORIGINAL: tail strike
It was working but I did not see it. A combination of low differential setting, need for subtrim on left aileron and viewing angle.
I dialed the differential way up and then saw that it was working OK.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
