Another crystal question..
My question is this. Can I use another brand of crystal in a Futaba receiver, assuming of course that it's the same channel?
Maybe, maybe not. Depends what other brand and what type of receiver (single/dual conversion). It's a lot easier and safer to use the correct crystal.
That said, most makes of single conversion crystal seem to be interchangeable. Steve |
No, crystal and receiver brands should never be mixed. All the manufacturers warn aginst this, they are cut differently for different brands. Some combos will work but at a probable range loss and some will not work at all.
John |
Hmmm, LHS employee said as long as they are the same channel there should not be a problem. But I didn't think that was right. I will check with Futaba to get the goods, and a crystal.
Originally posted by Aeronaut I will check with Futaba to get the goods, and a crystal. [/B] Good plan, enjoy :) John |
