How did you fit your 9Z with the FASST module in to the original TX case?
I have just got the TM7 module for my 9ZWC2 and I am planning which modifications to make to the foam inside the case to accept the radio without taking out the TM7 module.
Any ideas? Alfredo |
RE: How did you fit your 9Z with the FASST module in to the original TX case?
ORIGINAL: A Betancourt I have just got the TM7 module for my 9ZWC2 and I am planning which modifications to make to the foam inside the case to accept the radio without taking out the TM7 module. Any ideas? Alfredo Woodie |
Woodie:
Thank you, I will just add a couple of foam block to each side of the module to give extra support. What have been your experienxce with the TM7 in the 9Z? Regards, Alfredo |
ORIGINAL: A Betancourt Woodie: Thank you, I will just add a couple of foam block to each side of the module to give extra support. What have been your experienxce with the TM7 in the 9Z? Regards, Alfredo I will be buying a TM-14 and R6014 soon. From what I hear via these discussion groups as well as personal contacts, it is working very well also. Woodie |
