JR 9303 and Dual Elevator Servo programming ???
Can someone that has a JR 9303 tell how to program two elevator servos WITHOUT using a reverser, or matchbox ?? I was told by the LHS where I purchased it that it can be programmed into separate channels on the reciever and there would be no lag on the second servo? Is that true?
RE: JR 9303 and Dual Elevator Servo programming ???
- there is a dedicated program in it for elev- elev and Aux 2
In the X9303 it is "perfect" unless the operator fusses with subtrims |
where can I find instructions on how to do that? I just upgraded to the 9303 and still getting used to the menus?
Thanks |
If my memory serves me right , Don Sczur spelled it out a few years ago in the pattern forum. Check out his "build the Brio by the numbers". You'll have to search a bit , but its there.
Read page A-11 and A-14 in your manual(or on your disc if you have not printed it). An explanation is given on those pages.
Elevators
Plug one side of the elevator into the ELEV channel and the other side into the AUX. 3 channel. Go into the System menu and choose Wing TYPE. Jog over to the Mate line under ELEV and push the roller button. A box will appear with 4 choices: GEAR, AUX2, FLAP & AUX3, choose AUX3. You have just mated the AUX3 channel with the Elevator channel; the radio will now refer to these channels as REL (right elev.) and LEL |
