Make your own servo extentions ?
I bought the set up to make servo extentions. Not having much luck, getting the pins just right so they will fit into the connectors seems to be very difficlut. Any advice would be helpful.
RE: Make your own servo extentions ?
I find it easier to just cut off the connector and just splice in the appropriate length of wire.
Notice there are 2 sets of crimps on the connector pin, one for the wire insulation and one for the wire strands. Strip about 3/16" of the insulation from one end of the wire. You want the stripped portion to be long enough to extend through the wire strand crimps and bloom on the other side.
Notice in the gully the little peak in the center of the gully. Notice that it is on one side only. As you hold the tool pointing away from you, gully down, it is on the right. This turns the crimps (on your connector pin) into the wire (curls them inward) so they don't crash into each other. Start by crimping ONLY the insulation part and lightly, then move pin into tool fully so the wire strand crimps (on the connector pin) are over the little peak in the gully and crimp very tight. If there is any extra thickness (caused by insulation being squeezed out of the pin, the pins will not slide into the connector housing. Sometimes you need to trim the insulation with a razer blade. |
