RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   How to synchronize and reverse servos on split elevator (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/756392-how-synchronize-reverse-servos-split-elevator.html)
bruce119 05-08-2003 04:57 PM
I am doing a Dnya Flight Fly Baby it has split elevators. This is new to me. I'm using Hitec HS-605BB servos and a Futaba 4 chanel radio. I can't get them to match up perfectly and it worries me. I would like to keep it as simple and low cost as possible. I have 5 servos and none of them center exactly in the same spot. Any ideas or suggestions.
Bruce
WreckRman2 05-08-2003 05:05 PM
Well it's well known that the 605 servos have problems centering so if your that concerned you might start with better servos. Other than that it's mostly a matter of using the same servos, servo arms, control horns, etc... then just matching them at center.
SMALLFLY- 05-08-2003 05:38 PM
You havent given yourself much room for improvement. Any idea will cost you money.
1 a good computer radio with end point adjustments and split elevator features
2. a JR matchbox, will let you set end points.
3. a couple of digital servos programmed correctly on a borrowed programmer
Airbike 05-08-2003 07:58 PM
You might try a servo reversing Y-harness. I'm using one on my Razzle 3D plane. I think it was either from Cermark or from Expert electronics. This Y-harness that I'm using has an adjustment pot. to center the second servo. You can get nearly equal throws just by doing that. If you use a control horn that is basically a screw with an end fitting, then you can also adjust the distance from the hinge line to increase or decrease throws.
Hope this helps
