RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Tracker II flaperon work-around (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/767292-tracker-ii-flaperon-work-around.html)
strato911 05-12-2003 05:50 PM
Listen up all you Tracker II owners - I have been working on a work-around for those who haven't sent your transmitters in for the Flaperon update. It uses 2 of the 3 P-mixes, but it seems to work fine.
1). Set your wing mix to "no wing mix" in the Track 1 programming.
2). Select Data Save and press Data + to save.
3). Turn the Tx off, and back on for the change to take effect.
4). Assuming you want proportional flaps, connect ch 1 & 6 to your ailerons (if you want a flaps switch, use ch 5 wherever my instructions say ch 6)
5). Set your Flap rate to 50%
6). Set Pmix-1 master = ch 1, slave = ch 6, M => S rate = 100% and M <= S rate = -50%
7). Set Pmix-2 master = ch 6, slave = ch 6, M => S rate = -50%, and M <= S rate = 0%
8). Select Data Save/Exit and press Data + to save and exit.
There may be other ways, but this was the first method I found which works using rev 1.16 firmware. Slight experimentation with the posted percentages can be done to customize for your particular setup. If you are unsure of your firmware version, watch the display when you power up the Tx. Contact Polk's Hobbies to obtain the firmware update for free. I think the current revision is 1.2
Scar 05-13-2003 03:32 PM
Thanks, Strato!
Dave Olson
markdam 01-29-2004 06:25 PM
RE: Tracker II flaperon work-around
help i have a hitec 555 and want to use flaperons do i need to select a seprate switch for each mix??? i have the latest revision of the software ive tried all kinds of stuff but it wont give 100% throw to the slave AAAAAAARGGH
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
