servos
i am just about to get done building my new Midwest Cap 232. i am putting a 3w 48 bi twin engine on it, but having a hard time deciding what kind of servos to use. I'm using a Jr pcm 10 radio, but not too sure if i want to use Jr servos.
anyone has any suggestions? |
servos
It depends on your skills and how you intend to fly the plane as to what level of servos you would need.
In the Hitec line, I would look at the HS-645's as an economical choice, but highly recommend the HS-5945 digitals if you want the plane to perform to its maximum potential. The 5945's would compare to the JR 8411's in performance but will cost you about $25 less ea. You can compare all brands here: http://www.hitecrcd.com http://www.horizonhobby.com http://www.futabarc.com http://www.airtronics.net http://www.multiplexusa.com Mike. |
