JR 9303 programming help
Hello Looking for the best place to get programming guide info for a Jr 9303 synthesized radio when it gets here. just trying to get a jump on the reading.
any input or help locating the best guides would be appreciated. mainly. got several models with 6 servos 2 ailerons 2 elevator 1 rudder and one throttle. |
RE: JR 9303 programming help
9303 Dual Aileron,Elevator,Flap,Retract
Device Select: GEAR FLAP AUX2 AUX3 AUX4 INH ACT INH INH ACT NOTE: Shadow AUX4, press roller and Assign GEAR SWITCH Wing Type: Normal Dual: AILE ELEV RUDD FLAP Mate: AUX2 AUX3 INH GEAR Now go to the Function Menu: Monitor Check it out..Aux#4=Retracts..activated By the retract switch. |
#1 Go to WING TYPE: NORMAL
#2 Rotate the Roller until you are under AILE, Press the Roller and Select AUX2, rotate the Roller until you are under FLAP, Press the Roller and select AUX3 (you have the choice of selecting TRIM or INH..this might help trimming the FLAP on AUX3) #3 Go to DEVICE SELECT and Rotate the roller until you are under AUX2(on the bottom of the screen Press the Roller and INH AUX2, Rotate the Roller until you are Under AUX3, Press the Roller and INH AUX3 #4 You may have to REVERSE AUX2 or AUX3 or both depends on the hook Up of the linkage. #5 Just remember that any change on Aileron Travel adjustment, has to be done on AUX2, and the same for Flaps and AUX3. #6 NOTE: Connect Right Aileron to Aileron, and Left Aileron to AUX2. The same for the Flaps, Right FLAP to Flap…Left Flap to AUX3 |
Hook up 2 Servo Aileron non Flaperon
#1. Go to DEVICE SELECT and rotate the roller until you are under AUX2 (on the bottom of the screen), Press the roller and INH AUX2. #2. Go to WING TYPE: NORMAL and rotate the roller until you are under AILE, Press the roller and select AUX2. Hook up 2 Servo Elevator #1. Go to DEVICE SELECT and rotate the roller until you are under AUX3 (on the bottom of the screen), Press the roller and INH AUX3 #2. Go to WING TYPE: NORMAL and rotate the roller until you are under ELEV, Press the roller and select AUX3. NOTE: You may have to REVERSE AUX2 OR AUX3 or both depends on the hookup of the linkage. NOTE: Connect Right Aileron to Aileron and Left Aileron to Aux2. The same for the Elevators Right Elevator to Elevator and Left Elevator to Aux3. |
FLAPERONS/FLAPS/ELEVATOR
Go to Main Menu. Go to WING TYPE: Set Wing to FLAPERONS. Go to Secondary Menu. Rotate roller to FLAP SYSTEM: Rotate until ELEV Land, press roller down, rotate until it reads D 10 o/o, Press Down on roller. Rotate until FLAP Land, press roller down, rotate until it reads D 50 o/o, Press down on roller. Rotate roller until you are at LST, Press roller, rotate until you are at Monitor, Press roller, now you can monitor the action when you press the FLAP Switch down, the Ailerons will droop, and slight down Elevator. NOTE: The amount of FLAP and Down ELEVATOR, must be test flown first to ADD or SUBTRACT..Flap or Elevator. |
ORIGINAL: Big-Mo Hello Looking for the best place to get programming guide info for a Jr 9303 synthesized radio when it gets here. just trying to get a jump on the reading. any input or help locating the best guides would be appreciated. mainly. got several models with 6 servos 2 ailerons 2 elevator 1 rudder and one throttle. |
I love the 9303 and I have two Tx's, but the manual does not explain everything clearly. The radio is fantastic, but the manual is lacking in several areas. The same can be said for the Futaba T7C FASST, so I am not just picking on JR.
My first computer radio was the Futaba T6XA. I progressed to the 7UAPS, 8AUPS, and 9CAP. As the complexity increased, the manuals became more technical. The How To was there, but how to set up real world scenarios was not. Don Edberg did a great job writing 3rd party books with Real World scenarios. I never would have guessed how to use two Programmable Mixers to put Flaps on a switch. When I bought a used XP8103, I found features that were missing from the 9CAP. When the XP9303 came out, it was clearly superior to the 9CAP. The manual was not as well designed. When is a manual going to be written by people who actually use all the features of the radio? |
Thanks all for the info .
Airbusdrvr this is why i asked BEFORE the radio got here. thats why the message of looking for reading material for programming before the radio gets here. Joeraf: Thanks so much for the pdf link to the manual. Sure Hoping this radio is what I'm expecting. Thanks again Big-Mo Don |
