JR R770S Receiver Aerial Length
hi guys
My aerial went through the ducting of my jet so need to know the length so i can replace it. Thanks Mattyb |
39"
Lee |
Re: JR R770S Receiver Aerial Length
The JR 770 is not sold in North America, but here all JR Receiver antenna are 39"
Originally posted by Mattyb hi guys My aerial went through the ducting of my jet so need to know the length so i can replace it. Thanks Mattyb |
hmmm ok
wonder if its different here in Australia. The fact that we are on 36 mghz would make a diff??? |
Well I don't know, but let say that I would contact either a dealer or a service repair to find out.
Since 39" or a meter I would bet that it's the same, but i don't bet with my airplanes, all of mine are worth more then the receiver:) |
There is no difference in component values between a JR 35Mhz and 36Mhz receiver. JR only produce one receiver for both Aussy' land and Pommie land. The differences are removable crystal and altered tuning.
JR antenna length is a standard 39" or 1 metre for 27,29,35,36,40,50,53 and 72 Mhz receivers. The only exception to this are early R610 receivers (Park & Fly) whose antenna length was 60cm or 24". Later ones being retuned to take the 39"/1metre antenna to give full range. |
